跳转到主内容
Dell Inspiron 15 7579 RAM (Memory) Replacement
你所需要的
  1. Dell Inspiron 15 7579 RAM (Memory) Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 RAM (Memory) Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15 7579 RAM (Memory) Replacement: 步骤 2 中的图像 2,2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 RAM (Memory) Replacement, RAM (Memory): 步骤 3 中的图像 1,1
    • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
  4. Dell Inspiron 15 7579 RAM (Memory) Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 15 7579 RAM (Memory) Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 15 7579 RAM (Memory) Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
    • Remove the chip by pulling at the same angle as the chip with the tweezers.
  5. Dell Inspiron 15 7579 RAM (Memory) Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 15 7579 RAM (Memory) Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 15 7579 RAM (Memory) Replacement: 步骤 5 中的图像 3,3
    • Fold the plastic flap over on the other side.
    • As before, pull the fasteners away from the chip with the tweezers.
    • Remove the chip by carefully pulling it out with the tweezers.
  6. Dell Inspiron 15 7579 RAM (Memory) Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 15 7579 RAM (Memory) Replacement: 步骤 6 中的图像 2,2
    • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
    • Doing otherwise will break the stick if forced.
结论
Inaki Madrigal
于04/23/18注册
775 声望
创作了6篇指南
团队
Cal Poly, Team S24-G9, Maness Spring 2018 Cal Poly, Team S24-G9, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G9
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 19
总计 749
