跳转到主内容
Dell Inspiron 15 7579 Battery Replacement
你所需要的
  1. Dell Inspiron 15 7579 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15 7579 Battery Replacement: 步骤 2 中的图像 2,2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 Battery Replacement, Battery: 步骤 3 中的图像 1,2 Dell Inspiron 15 7579 Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
  4. Dell Inspiron 15 7579 Battery Replacement: 步骤 4 中的图像 1,1
    • Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
    • Remove the battery from the device.
结论
10等其他人完成本指南。
Inaki Madrigal
于04/23/18注册
775 声望
创作了6篇指南
团队
Cal Poly, Team S24-G9, Maness Spring 2018 Cal Poly, Team S24-G9, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G9
4 名成员
创作了6篇指南
2条评论
Thanks! Very helpful and to the point!
You ARE TECHNICALLY missing one step however, removing the fabric ribbon from the old battery at the end. Yes, it seems like common sense but…
Anyways, thanks.
Thomas Keats - 回复
Thanks for the help, worked well.
Remember the connector needs to be removed from the old battery and re-installed in the new. I used a small slotted screwdriver.
A. Holness
June 7, 2020
andrew.w.holness - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 40
总计 7,113
