跳转到主内容
Dell Inspiron 15 7560 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 15 7560 Hard Drive Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Remove the four screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
  2. Dell Inspiron 15 7560 Hard Drive Replacement, Lifting the Hard Drive: 步骤 2 中的图像 1,1
    • Lift the hard-drive assembly off the palm rest and keyboard assembly.
  3. Dell Inspiron 15 7560 Hard Drive Replacement, Disconnect the Interposer: 步骤 3 中的图像 1,1
    • Disconnect the interposer from the hard-drive assembly.
  4. Dell Inspiron 15 7560 Hard Drive Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15 7560 Hard Drive Replacement, Lifting the Hard Drive Bracket: 步骤 5 中的图像 1,1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15 7560 Hard Drive Replacement, Align the Screw Holes: 步骤 6 中的图像 1,1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15 7560 Hard Drive Replacement, Replace the Screws: 步骤 7 中的图像 1,1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15 7560 Hard Drive Replacement, Connect the Interposer: 步骤 8 中的图像 1,1
    • Connect the interposer to the hard-drive assembly.
  9. Dell Inspiron 15 7560 Hard Drive Replacement, Align the Screw Holes: 步骤 9 中的图像 1,1
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
  10. Dell Inspiron 15 7560 Hard Drive Replacement, Replace the Screws: 步骤 10 中的图像 1,1
    • Replace the four screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
终点
另外一个人完成了本指南。
Terrence15
于12/18/17注册
79,121 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
一条评论
is the hard drive where the os is installed or in the m.2 drive and can i use a wd blue 512gb 3d nand ssd
Ethan Abraham - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,067
