跳转到主内容
Dell Inspiron 15 7560 Fan Replacement
你所需要的
  1. Dell Inspiron 15 7560 Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Power off the laptop.
    • Place the laptop with the bottom facing upwards.
    • Remove eight 5 mm screws from the bottom of the laptop.
    • Loosen the three captive screws.
    • Use an iFixit opening tool to pry the bottom cover away from the laptop.
  2. Dell Inspiron 15 7560 Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the two screws from the fan.
  3. Dell Inspiron 15 7560 Fan Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15 7560 Fan Replacement: 步骤 3 中的图像 2,2
    • Remove the black insulating tape from the fan connector.
    • Pinch the sides of the white fan connector with your thumb and index fingernail and pull it out of its socket.
    • Remove the fan from the laptop.
    • Save the insulating tape for reinstallation.
  4. Dell Inspiron 15 7560 Fan Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15 7560 Fan Replacement: 步骤 4 中的图像 2,2
    • Place the new fan in the laptop.
    • Plug the cable connector into its socket on the motherboard.
    • Replace the two screws around the fan.
  5. Dell Inspiron 15 7560 Fan Replacement: 步骤 5 中的图像 1,1
    • Before replacing the bottom cover, start the computer to check if the cooling fan is installed successfully.
  6. Dell Inspiron 15 7560 Fan Replacement: 步骤 6 中的图像 1,1
    • Power down the computer.
    • Reassemble the bottom cover.
终点
Kristen Gismondi
于11/12/14注册
92,066 声望
创作了241篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,453篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 32
总计 907
