跳转到主内容
Dell Inspiron 15 5584 RAM Replacement
你所需要的
  1. Dell Inspiron 15 5584 RAM Replacement, Bottom Cover: 步骤 1 中的图像 1,1
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 RAM Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 15 5584 RAM Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 15 5584 RAM Replacement: 步骤 2 中的图像 3,3
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 RAM Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15 5584 RAM Replacement: 步骤 3 中的图像 2,2
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 RAM Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15 5584 RAM Replacement: 步骤 4 中的图像 2,2
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 RAM Replacement, Battery: 步骤 5 中的图像 1,2 Dell Inspiron 15 5584 RAM Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 RAM Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 15 5584 RAM Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 15 5584 RAM Replacement: 步骤 6 中的图像 3,3
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
  7. Dell Inspiron 15 5584 RAM Replacement, RAM: 步骤 7 中的图像 1,1
    • Firmly apply pressure on the two latches to the right and left of the RAM stick.
  8. Dell Inspiron 15 5584 RAM Replacement: 步骤 8 中的图像 1,1
    • At an angle, gently pull the RAM stick out of the socket.
    • Remove the RAM stick from the motherboard socket.
结论
另外一个人完成了本指南。
Sam Vorn
于03/29/22注册
977 声望
创作了9篇指南
团队
UMass Dartmouth, Team 1-1, Mellen Spring 2022 UMass Dartmouth, Team 1-1, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S1G1
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 267
