简介
In this guide, we will be showing you how to remove and replace the Hard Drive.
你所需要的
Using the pull tab, disconnect the hard-drive cable from the system board.
Peel off the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
Note the hard-drive cable routing and remove the cable from the routing guides.
Remove the three screws (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
Lift the hard-drive assembly along with its cable off the palm rest and keyboard assembly.
Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
Align the screw holes on the hard-drive assembly with the screw holes on the palm rest and keyboard assembly.
Replace the screws three (M2x3) that secure the hard-drive assembly to the palm rest and keyboard assembly.
Route the hard-drive cable through the routing guides on the palm rest and keyboard assembly.
Adhere the tape that secures the hard-drive cable to the palm rest and keyboard assembly.
另外一个人完成了本指南。
