跳转到主内容
Dell Inspiron 15 5577 Gaming Hard-Drive Replacement
你所需要的
  1. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement, Hard-Drive: 步骤 1 中的图像 1,1
    • Turn your Dell Inspiron laptop up side down to locate a screw at the top of the device.
    • Unscrew the back cover with your Phillips Head screwdriver.
  2. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover. If you're having difficulty removing it, use a plastic opening tool, and pry the back cover away from the laptop.
  3. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 步骤 3 中的图像 1,1
    • Unscrew all 4 screws located around the hard drive.
  4. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 步骤 4 中的图像 1,1
    • Remove the cable above the hard drive. This can be done with a gentle tug perpendicular to the surface it is attached to.
  5. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the hard drive. If you're having difficulty removing it, use a plastic opening tool.
  6. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 步骤 6 中的图像 1,1
    • Unscrew the four screws on the hard drive casing.
  7. Dell Inspiron 15 5577 Gaming Hard-Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the hard drive casing. If you're having difficulty removing it, use a plastic opening tool.
结论
[deleted]
于10/31/19注册
346 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 30
总计 810
