简介
After multiple cycles of charging your battery, it will eventually no longer be able to hold a charge and you'll need to replace it. This is a simple battery replacement guide for the Dell Inspiron 15 3593.
Before using this guide, please make sure that the laptop is physically unplugged as well as turned off during the replacement.
你所需要的
Turn the computer upside down so its backside is facing you and place on a flat and clean surface to work.
Use a Phillips #0 screwdriver to remove six (M2.5x7mm) screws, three (M2x2mm) screws, and one (M2x4mm) screw.
Remove the optical drive.
Reassemble the computer by following
the above steps in reversed order.
2等其他人完成本指南。
2条评论
So where is the rest of the story?
