跳转到主内容
Dell Inspiron 15 3593 Battery Replacement
你所需要的
  1. Dell Inspiron 15 3593 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 15 3593 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • First, make sure the computer is turned off and unplugged.
    • Turn the computer upside down so its backside is facing you and place on a flat and clean surface to work.
    • Use a Phillips #0 screwdriver to remove six (M2.5x7mm) screws, three (M2x2mm) screws, and one (M2x4mm) screw.
    • Remove the optical drive.
  2. Dell Inspiron 15 3593 Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 15 3593 Battery Replacement: 步骤 2 中的图像 2,2
    • Turn the laptop over and open the lid so the screen faces you.
    • Use the plastic opening tool to gently pry the top panel with keyboard off of the computer. Work your way around the perimeter and undo the clips holding it down.
    • Don't use a butter knife like in the photo, as this could cause damage to the device.
  3. Dell Inspiron 15 3593 Battery Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 15 3593 Battery Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 15 3593 Battery Replacement: 步骤 3 中的图像 3,3
    • Close the lid and flip the laptop so the backside is facing up.
    • Pull the back panel off to reveal the battery.
  4. Dell Inspiron 15 3593 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15 3593 Battery Replacement: 步骤 4 中的图像 2,2
    • Disconnect the battery connector from the motherboard.
    • Use the Phillips #0 screwdriver to remove the four (M2x3mm) screws that are keeping the battery in place.
  5. Dell Inspiron 15 3593 Battery Replacement: 步骤 5 中的图像 1,1
    • Lift the battery out carefully and put the new battery in.
结论
Reassemble the computer by following
the above steps in reversed order.
2等其他人完成本指南。
Abdul Obaid
于01/13/22注册
169 声望
撰写一个指南
团队
2条评论
not all of the steps
there is somethings missing
aaaa2020 - 回复
So where is the rest of the story?
Jeanette Martinez - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 33
过去 30 天: 102
总计 2,657
