跳转到主内容
Dell Inspiron 15 3559 Memory Module Replacement
  1. Dell Inspiron 15 3559 Memory Module Replacement, Popping up the Memory Module: 步骤 1 中的图像 1,2 Dell Inspiron 15 3559 Memory Module Replacement, Popping up the Memory Module: 步骤 1 中的图像 2,2
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Using your fingertips, pry apart the securing clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15 3559 Memory Module Replacement, Removing the Memory Module: 步骤 2 中的图像 1,1
    • Slide and remove the memory module from the memory-module slot.
  3. Dell Inspiron 15 3559 Memory Module Replacement, Align the Notch: 步骤 3 中的图像 1,2 Dell Inspiron 15 3559 Memory Module Replacement, Align the Notch: 步骤 3 中的图像 2,2
    • Align the notch on the NEW memory module with the tab on the memory-module slot.
  4. Dell Inspiron 15 3559 Memory Module Replacement, Sliding the Memory Module: 步骤 4 中的图像 1,1
    • Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it.
终点
Terrence15
于12/18/17注册
79,831 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,991篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 670
