跳转到主内容
Dell Inspiron 15 3541 Keyboard Replacement
你所需要的
  1. Dell Inspiron 15 3541 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 15 3541 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 3541 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,2 Dell Inspiron 15 3541 Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Open the laptop and fully extend the screen.
    • Using the nylon spudger, pry the keyboard off the laptop body.
    • Using your hands, remove the keyboard from the body and place it facedown on the track pad. There will be a cord connecting the laptop and the keyboard: keep this cord intact.
  4. Dell Inspiron 15 3541 Keyboard Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15 3541 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Unhook the connector and you can now remove the keyboard from the laptop
    • If your version of this laptop has a backlit keyboard, there will be two connectors; the one highlighted orange will also have to be removed.
结论
8等其他人完成本指南。
Allison
于03/04/16注册
571 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-8, Landers Spring 2016 UMass Dartmouth, Team 5-8, Landers Spring 2016 的会员
UMASSD-LANDERS-S16S5G8
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 31
总计 3,534
