跳转到主内容
Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement
你所需要的
  1. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, Battery removal: 步骤 1 中的图像 1,1
    • Turn the laptop over and unlock the battery by sliding the two locking tabs away from each other. The one on the left is spring loaded. Slide the battery out.
    • Simply slide the battery out in the direction shown.
  2. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, RAM removal: 步骤 2 中的图像 1,2 Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, RAM removal: 步骤 2 中的图像 2,2
    • Undo the locking screw on RAM cover, then prise open the cover.
    • Release the RAM module or modules by pushing the metal clips outwards. Put the modules aside.
    • On reinserting the RAM modules, ensure that they are fully home in their sockets before angling them downwards to engage the clips.
  3. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, Bottom screws: 步骤 3 中的图像 1,2 Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, Bottom screws: 步骤 3 中的图像 2,2
    • Note: if the laptop you are working on is a very slightly different model it is possible that it will have a different number of screws in slightly different positions. The important thing is to note where the shorter screws come from so as to avoid inserting a longer screw in its place on reassembly.
    • Remove a 5mm screw to the left of the RAM sockets, then pull out the CD/DVD drive. (Not necessary if you are only replacing the keyboard.)
    • Remove a 5mm screw to the right and the rear of the RAM sockets.
    • If you are going to remove the hard disk, motherboard or fan, remove 4 3mm screws.
    • Remove 7 5mm screws. (There are 6 more at the rear which should be left.)
  4. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement: 步骤 4 中的图像 2,2
    • With a thin metal spudger you should now be able to release 4 clips along the top of the keyboard in order to lift it out.
    • If you find one or more of the tabs refuse to release, do not force it. You probably missed one (or more) of the screws in the bottom.
    • Lift the keyboard slightly from the back, disengaging its tabs along the front panel at the front. Turn it over towards you, taking care not to strain the ribbon.
    • Gently lift the locking bar on the ribbon socket and withdraw the ribbon. Put the keyboard aside.
结论
Philip Le Riche
于02/18/14注册
30,213 声望
创作了47篇指南
团队
Restart Project Restart Project 的会员
Local Repair Groups
19 名成员
创作了561篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 782
