跳转到主内容
Dell Inspiron 14z-5423 Wireless Mini Card Replacement
你所需要的
  1. Dell Inspiron 14z-5423 Wireless Mini Card Replacement, RAM: 步骤 1 中的图像 1,2 Dell Inspiron 14z-5423 Wireless Mini Card Replacement, RAM: 步骤 1 中的图像 2,2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 2 中的图像 1,1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 3 中的图像 2,2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 4 中的图像 2,2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 5 中的图像 2,2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Wireless Mini Card Replacement, Optical Drive: 步骤 6 中的图像 1,2 Dell Inspiron 14z-5423 Wireless Mini Card Replacement, Optical Drive: 步骤 6 中的图像 2,2
    • Slide the CD/DVD drive on the side of the laptop out using your fingers.
    • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
    • You only need to unscrew this screw if you are using this as a prerequisite guide.
  7. Dell Inspiron 14z-5423 Wireless Mini Card Replacement, Keyboard: 步骤 7 中的图像 1,3 Dell Inspiron 14z-5423 Wireless Mini Card Replacement, Keyboard: 步骤 7 中的图像 2,3 Dell Inspiron 14z-5423 Wireless Mini Card Replacement, Keyboard: 步骤 7 中的图像 3,3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  8. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 8 中的图像 1,1
    • Flip over the computer and open the display.
  9. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 9 中的图像 2,2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  10. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 10 中的图像 1,2 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 10 中的图像 2,2
    • Flip the keyboard over onto the palm-rest assembly.
  11. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 11 中的图像 1,3 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 11 中的图像 2,3 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 11 中的图像 3,3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
  12. Dell Inspiron 14z-5423 Wireless Mini Card Replacement, Palm Rest Assembly: 步骤 12 中的图像 1,1
  13. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 13 中的图像 1,3 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 13 中的图像 2,3 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 13 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove all 7 rubber screw caps with tweezers.
    • Use a J0 Bit tipped screwdriver unscrew the seven 6 mm Phillips screws on the back casing of the laptop.
  14. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 14 中的图像 1,2 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 14 中的图像 2,2
    • Flip the computer over and open the display.
    • Pull on the blue tabs to disconnect the palm rest assembly from the computer.
  15. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 15 中的图像 1,1
    • Use J0 Bit screwdriver to remove all four 6 mm Phillips screws.
  16. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 16 中的图像 1,3 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 16 中的图像 2,3 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 16 中的图像 3,3
    • Gently wedge the nylon spudger underneath the palm-rest assembly to release the latches.
    • Continue this process on all sides of the computer edges until the assembly pulls off.
    • Remove the palm rest assembly.
    • If you have difficulty lifting up the assembly, you might not have taken out all 7 screws on the bottom of the computer.
  17. Dell Inspiron 14z-5423 Wireless Mini Card Replacement, Wireless Mini Card: 步骤 17 中的图像 1,2 Dell Inspiron 14z-5423 Wireless Mini Card Replacement, Wireless Mini Card: 步骤 17 中的图像 2,2
    • Locate the wireless mini card at the top of the laptop.
    • It is next to the place where the optics drive used to be.
  18. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 18 中的图像 1,1
    • Using a J0 tipped screwdriver, remove the 4 mm Phillips head screw.
  19. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 19 中的图像 1,2 Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 19 中的图像 2,2
    • Gently, unlatch the black and white wires from the wireless mini card.
  20. Dell Inspiron 14z-5423 Wireless Mini Card Replacement: 步骤 20 中的图像 1,1
    • At an angle, slide out the wireless mini card.
结论
Brittany
于09/12/16注册
914 声望
创作了4篇指南
团队
CSU Fullerton, Team 2-2, Bruce Fall 2016 CSU Fullerton, Team 2-2, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S2G2
5 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 22
总计 747
