跳转到主内容
Dell Inspiron 14z-5423 Optical Drive Replacement
你所需要的
  1. Dell Inspiron 14z-5423 Optical Drive Replacement, RAM: 步骤 1 中的图像 1,2 Dell Inspiron 14z-5423 Optical Drive Replacement, RAM: 步骤 1 中的图像 2,2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Optical Drive Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 14z-5423 Optical Drive Replacement: 步骤 3 中的图像 2,2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Optical Drive Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 14z-5423 Optical Drive Replacement: 步骤 4 中的图像 2,2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Optical Drive Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 14z-5423 Optical Drive Replacement: 步骤 5 中的图像 2,2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Optical Drive Replacement, Optical Drive: 步骤 6 中的图像 1,2 Dell Inspiron 14z-5423 Optical Drive Replacement, Optical Drive: 步骤 6 中的图像 2,2
    • Slide the CD/DVD drive on the side of the laptop out using your fingers.
    • Using a J0 bit screwdriver, unscrew the one 2 mm Phillips screw.
    • You only need to unscrew this screw if you are using this as a prerequisite guide.
结论
Marisol
于09/12/16注册
623 声望
创作了4篇指南
团队
CSU Fullerton, Team 2-2, Bruce Fall 2016 CSU Fullerton, Team 2-2, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S2G2
5 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 672
