跳转到主内容
Dell Inspiron 14z-5423 Keyboard Replacement
你所需要的
  1. Dell Inspiron 14z-5423 Keyboard Replacement, RAM: 步骤 1 中的图像 1,2 Dell Inspiron 14z-5423 Keyboard Replacement, RAM: 步骤 1 中的图像 2,2
    • Close the display and turn over the computer.
    • Make sure your device is powered down and unplugged before beginning the replacement.
  2. Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Use a J0 bit tipped screwdriver to unscrew the one 6 mm Phillips screw on the RAM cover.
  3. Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 3 中的图像 2,2
    • Lightly lift the RAM cover up and at an angle, away from the computer.
  4. Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Use your fingers to carefully pull the securing clips on the RAM away from each other.
    • The RAM should pop up when the clips are released.
  5. Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Remove the popped up RAM by pulling it away from the connection.
    • If it does not pop up pry it out in a steady and straight direction.
  6. Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: 步骤 6 中的图像 2,3 Dell Inspiron 14z-5423 Keyboard Replacement, Keyboard: 步骤 6 中的图像 3,3
    • Lift the plastic yellow flap on the system board.
    • Use the J0 Bit screwdriver to remove the one 6 mm Phillips screw in center of the system board that is connected to the keyboard.
  7. Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Flip over the computer and open the display.
  8. Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 8 中的图像 1,2 Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Insert a spudger next to the plastic indents located at the top of the keyboard and gently pry to release the securing clips.
    • Lift the keyboard off of the computer.
    • Be careful not to tear the ribbon that attaches the back of the keyboard to the computer when lifting it.
  9. Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 9 中的图像 2,2
    • Flip the keyboard over onto the palm-rest assembly.
  10. Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 10 中的图像 1,3 Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 10 中的图像 2,3 Dell Inspiron 14z-5423 Keyboard Replacement: 步骤 10 中的图像 3,3
    • Flip the little black securing bar near the base of the ribbon with a spudger to release the ribbon from the computer.
结论
2等其他人完成本指南。
Marisol
于09/12/16注册
623 声望
创作了4篇指南
团队
CSU Fullerton, Team 2-2, Bruce Fall 2016 CSU Fullerton, Team 2-2, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S2G2
5 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 1,479
