跳转到主内容
Dell Inspiron 14z N114z Display Assembly Replacement
你所需要的
  1. Dell Inspiron 14z N114z Display Assembly Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the computer base.
  2. Dell Inspiron 14z N114z Display Assembly Replacement, Turn over the Computer: 步骤 2 中的图像 1,1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron 14z N114z Display Assembly Replacement, Lifting the Connector Latch: 步骤 3 中的图像 1,1
    • Lift the connector latch and disconnect the display cable from the connector on the system board.
  4. Dell Inspiron 14z N114z Display Assembly Replacement, Note the Routing: 步骤 4 中的图像 1,1
    • Note the routing of the display, camera, and mini-card antenna cables, and remove the cables from their routing guides.
  5. Dell Inspiron 14z N114z Display Assembly Replacement, Remove the Screws: 步骤 5 中的图像 1,1
  6. Dell Inspiron 14z N114z Display Assembly Replacement, Lifting the Display Assembly: 步骤 6 中的图像 1,1
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 14z N114z Display Assembly Replacement, Placing the Display Assembly: 步骤 7 中的图像 1,2 Dell Inspiron 14z N114z Display Assembly Replacement, Placing the Display Assembly: 步骤 7 中的图像 2,2
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
    • NOTE: Ensure that no cables are caught between the display assembly and the computer base.
  8. Dell Inspiron 14z N114z Display Assembly Replacement, Route the Cables: 步骤 8 中的图像 1,1
    • Route the display, camera, and mini-card antenna cables through their routing guides.
  9. Dell Inspiron 14z N114z Display Assembly Replacement, Sliding the Display Cable: 步骤 9 中的图像 1,1
    • Slide the display cable in the connector on the system board and press down the latch to secure the cable.
  10. Dell Inspiron 14z N114z Display Assembly Replacement, Replace the Screws: 步骤 10 中的图像 1,1
    • Turn the computer over.
    • Replace the two screws that secure the display assembly to the computer base.
终点
另外一个人完成了本指南。
Terrence15
于12/18/17注册
79,831 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,991篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 273
