跳转到主内容
Dell Inspiron 14z 1470 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 14z 1470 Hard Drive Replacement, Disconnecting the Audio Cable: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • Disconnect the USB/audio cable from the system board.
  2. Dell Inspiron 14z 1470 Hard Drive Replacement, Remove the Screws: 步骤 2 中的图像 1,1
    • Remove the four screws that secure the hard drive assembly to the computer base.
  3. Dell Inspiron 14z 1470 Hard Drive Replacement, Lifting the Hard Drive Assembly: 步骤 3 中的图像 1,1
    • Slide and lift the hard drive assembly out of the computer base.
  4. Dell Inspiron 14z 1470 Hard Drive Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the four screws that secure the hard drive to the hard drive bracket.
  5. Dell Inspiron 14z 1470 Hard Drive Replacement, Remove the Hard Drive: 步骤 5 中的图像 1,1
    • Remove the hard drive.
  6. Dell Inspiron 14z 1470 Hard Drive Replacement, Placing the Hard Drive: 步骤 6 中的图像 1,1
    • Place the NEW hard drive in the hard drive bracket and replace the four screws that secure the hard drive bracket to the hard drive.
  7. Dell Inspiron 14z 1470 Hard Drive Replacement, Sliding the Hard Drive: 步骤 7 中的图像 1,1
    • Slide the hard drive assembly into the computer base until it is fully seated.
  8. Dell Inspiron 14z 1470 Hard Drive Replacement, Replace the Screws: 步骤 8 中的图像 1,1
    • Replace the four screws that secure the hard drive assembly to the computer base.
  9. Dell Inspiron 14z 1470 Hard Drive Replacement, Connecting the Cable: 步骤 9 中的图像 1,1
    • Connect the USB/audio cable to the USB/audio board.
终点
Terrence15
于12/18/17注册
79,243 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,989篇指南
一条评论
Como fazer a manutenção da placa mãe
Claudio - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 12
总计 1,024
