跳转到主内容
Dell Inspiron 14R-5421 Keyboard Replacement
你所需要的
  1. Dell Inspiron 14R-5421 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Push the two sliders away from the battery towards the outer edges.
  2. Dell Inspiron 14R-5421 Keyboard Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 14R-5421 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Remove the battery when it pops up.
  3. Dell Inspiron 14R-5421 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Find the clips on the keyboard. They are shown by red arrows.
  4. Dell Inspiron 14R-5421 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Using a pry tool, detach the 9 clips from the keyboard by prying at a 90 degree angle.
    • Be careful while detaching and do not lift the keyboard too high or be too rough. The keys can break easily and there is a fragile ribbon cable beneath the keyboard.
  5. Dell Inspiron 14R-5421 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Carefully disconnect the ribbon cable from the socket and pull apart.
    • The cable could be connected to other components of the laptop. Proceed with caution because the cable is fragile.
结论
Jared paiva
于03/27/18注册
489 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 539
