跳转到主内容
Dell Inspiron 14R SE 7420 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Disconnecting the Hard Drive Cable: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Pull the pull-tab to disconnect the hard-drive cable from the system-board connector.
  2. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Remove the Screws: 步骤 2 中的图像 1,1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Removing the Cable: 步骤 3 中的图像 1,1
    • Make a note of the hard-drive cable routing and remove the cable from the routing guides.
  4. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 步骤 4 中的图像 1,1
    • Lift the hard-drive assembly along with its cable away from the computer base.
  5. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Pull the Interposer: 步骤 5 中的图像 1,1
    • Pull the interposer to disconnect the hard-drive cable from the hard-drive.
  6. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Remove the Screws: 步骤 6 中的图像 1,1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Sliding the Hard Drive: 步骤 7 中的图像 1,1
    • Slide the hard-drive off the hard-drive bracket.
  8. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Align the Screw Holes: 步骤 8 中的图像 1,1
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Replace the Screws: 步骤 9 中的图像 1,1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Connecting the Interposer: 步骤 10 中的图像 1,1
    • Connect the hard-drive cable interposer to the hard drive.
  11. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Place the Hard-Drive Assembly: 步骤 11 中的图像 1,1
    • Place the hard-drive assembly in the hard-drive bay on the computer base.
  12. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Replace the Screws: 步骤 12 中的图像 1,1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Routing the Hard-Drive Cable: 步骤 13 中的图像 1,1
    • Route the hard-drive cable through the routing guides on the computer base.
  14. Dell Inspiron 14R SE 7420 Hard Drive Replacement, Connecting the Hard Drive Cable: 步骤 14 中的图像 1,1
    • Connect the hard-drive cable to the system-board connector.
终点
Terrence15
于12/18/17注册
79,121 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 220
