跳转到主内容
Dell Inspiron 14R SE 7420 Display Assembly Replacement
你所需要的
  1. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Close the Display: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • Close the display and turn the computer over.
  2. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Remove the Screws: 步骤 2 中的图像 1,1
    • Remove the screws that secure the display assembly to the computer base.
  3. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Open the Display: 步骤 3 中的图像 1,1
    • Turn the computer over and open the display as far as possible.
  4. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Disconnecting the Antenna Cables: 步骤 4 中的图像 1,1
    • Disconnect the antenna cables from the connectors on the Mini-Card.
  5. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Remove the Screws: 步骤 5 中的图像 1,1
  6. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Lifting the Display Assembly: 步骤 6 中的图像 1,1
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Placing the Display Assembly: 步骤 7 中的图像 1,2 Dell Inspiron 14R SE 7420 Display Assembly Replacement, Placing the Display Assembly: 步骤 7 中的图像 2,2
    • Place the display assembly in position and replace the screws that secure the display assembly to the computer base.
  8. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Connecting the Antenna Cables: 步骤 8 中的图像 1,1
    • Connect the antenna cables to the connectors on the Mini-Card.
  9. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Close the Display: 步骤 9 中的图像 1,1
  10. Dell Inspiron 14R SE 7420 Display Assembly Replacement, Replace the Screws: 步骤 10 中的图像 1,1
    • Replace the screws that secure the display assembly to the computer base.
终点
Terrence15
于12/18/17注册
79,309 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,984篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 358
