跳转到主内容
Dell Inspiron 14R Hard Drive Assembly Replacement
你所需要的
  1. Dell Inspiron 14R Hard Drive Assembly Replacement, Remove the Screw: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screw that secures the hard-drive assembly to the system board.
  2. Dell Inspiron 14R Hard Drive Assembly Replacement, Sliding the Hard-Drive Assembly: 步骤 2 中的图像 1,1
    • Slide the hard-drive assembly in the direction shown in the illustration to disconnect it from the connector on the system board.
  3. Dell Inspiron 14R Hard Drive Assembly Replacement, Lifting the Hard-Drive Assembly: 步骤 3 中的图像 1,1
    • Lift the hard-drive assembly off the system board.
  4. Dell Inspiron 14R Hard Drive Assembly Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14R Hard Drive Assembly Replacement, Lifting the Hard Drive: 步骤 5 中的图像 1,1
    • Lift the hard drive away from the hard-drive bracket.
  6. Dell Inspiron 14R Hard Drive Assembly Replacement, Placing the Hard Drive: 步骤 6 中的图像 1,1
    • Place the NEW hard drive in the hard-drive bracket.
  7. Dell Inspiron 14R Hard Drive Assembly Replacement, Replace the Screws: 步骤 7 中的图像 1,1
    • Replace the four screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 14R Hard Drive Assembly Replacement, Placing the Hard-Drive Assembly: 步骤 8 中的图像 1,1
    • Place the hard-drive assembly on the system board.
  9. Dell Inspiron 14R Hard Drive Assembly Replacement, Sliding the Hard Drive Assembly: 步骤 9 中的图像 1,1
    • Slide the hard-drive assembly to connect it to the connector on the system board.
  10. Dell Inspiron 14R Hard Drive Assembly Replacement, Replace the Screw: 步骤 10 中的图像 1,1
    • Replace the screw that secures the hard-drive assembly to the system board.
    • CAUTION: Before turning on the computer, replace all screws and ensure that no stray screws remain inside the computer. Failure to do so may result in damage to the computer.
终点
另外一个人完成了本指南。
Terrence15
于12/18/17注册
79,161 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,986篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 10
总计 182
