跳转到主内容
修复你的物品
维修的权力
商店
简介
In this guide, we will show you how to remove and replace the Display Assembly.
配件
没有特定配件。
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws from the computer base.
  2. Loosen the display cable grounding screw.
    • Loosen the display cable grounding screw.
  3. Disconnect the display cable from the connector on the system board.
    • Disconnect the display cable from the connector on the system board.
  4. Remove the four screws that secure  the display assembly to the computer  base.
    • Remove the four screws that secure the display assembly to the computer base.
  5. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  6. Lift the display assembly off the computer base.
    • Lift the display assembly off the computer base.
  7. Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
    • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
  8. Route the display cable and Mini-Card antenna cables through the routing  guides.
    • Route the display cable and Mini-Card antenna cables through the routing guides.
  9. Connect the display cable to the  connector on the system board.
    • Connect the display cable to the connector on the system board.
  10. Tighten the display cable grounding screw.
    • Tighten the display cable grounding screw.
  11. Replace the two screws at the bottom of the computer.
    • Replace the two screws at the bottom of the computer.
终点
Terrence15
于2017年12月18日注册
72,486 信誉积分
创作了442篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
21 名成员
创作了1,824篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 101
