跳转到主内容
Dell Inspiron 1440 Touch Pad Buttons Replacement
你所需要的
  1. Dell Inspiron 1440 Touch Pad Buttons Replacement, Keyboard: 步骤 1 中的图像 1,2 Dell Inspiron 1440 Touch Pad Buttons Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Take off the plastic strip with the speaker cover above the keyboard using an opening tool.
    • Once it pops out, pull it off.
  2. Dell Inspiron 1440 Touch Pad Buttons Replacement: 步骤 2 中的图像 1,1
    • Remove the screws at the top of the keyboard.
  3. Dell Inspiron 1440 Touch Pad Buttons Replacement: 步骤 3 中的图像 1,1
    • Lift from the top part of the keyboard and pull out.
  4. Dell Inspiron 1440 Touch Pad Buttons Replacement, Touch Pad Buttons: 步骤 4 中的图像 1,2 Dell Inspiron 1440 Touch Pad Buttons Replacement, Touch Pad Buttons: 步骤 4 中的图像 2,2
    • Remove all of the 6 mm screws on the bottom of the laptop.
    • There are some that go along the edge and some that surrounding and underneath a middle plate.
  5. Dell Inspiron 1440 Touch Pad Buttons Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 1440 Touch Pad Buttons Replacement: 步骤 5 中的图像 2,2
    • Remove the 6 mm screws that are in the silver metal plate under the keyboard.
    • Disconnect any wires that are attached to the metal plate.
  6. Dell Inspiron 1440 Touch Pad Buttons Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 1440 Touch Pad Buttons Replacement: 步骤 6 中的图像 2,2
    • Once all of the screws are out of the silver plate and the bottom of the laptop, pull silver plate, which is attached to the silver plastic on top, off of the laptop.
  7. Dell Inspiron 1440 Touch Pad Buttons Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 1440 Touch Pad Buttons Replacement: 步骤 7 中的图像 2,2
    • Flip over the silver plate, and remove the 3 mm screw attached the buttons.
    • Remove the ribbon cables that are also attached.
  8. Dell Inspiron 1440 Touch Pad Buttons Replacement: 步骤 8 中的图像 1,1
    • Remove the buttons.
结论
Tyler Lyons
于11/05/19注册
452 声望
创作了4篇指南
团队
UMass Dartmouth, Team S1-G3, Barthe Fall 2019 UMass Dartmouth, Team S1-G3, Barthe Fall 2019 的会员
UMASSD-BARTHE-F19S1G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 363
