跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Do you find your laptop is running slowly when you have multiple programs running? You may find the solution simpler than you may think. By upgrading your RAM, your computer may see some improvements in speed and performance.
  1. Slide the two tabs to release the battery. Pull the battery out. Pull the battery out.
    • Slide the two tabs to release the battery.
    • Pull the battery out.
  2. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  3. Using a Phillips #00 screwdriver, remove the three 2.5mm screws from the panel. Pull back the panel and set it aside. Pull back the panel and set it aside.
    • Using a Phillips #00 screwdriver, remove the three 2.5mm screws from the panel.
    • Pull back the panel and set it aside.
  4. Spread apart the securing clips on both ends of the chip until the module pops out. Remove the RAM from the connector. These represent the clips of a second module
    • Spread apart the securing clips on both ends of the chip until the module pops out.
    • Remove the RAM from the connector.
    • These represent the clips of a second module
结论
另外一个人完成了本指南。
Shaun Dinsmore
于2014年09月23日注册
52 信誉积分
创作了2篇指南
团队
USF Tampa, Team 2-4, Blackwell Fall 2014 USF Tampa, Team 2-4, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S2G4
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 9
总计 675
