跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 1420 Memory Module Replacement
你所需要的
  1. Dell Inspiron 1420 Memory Module Replacement, Loosen the Screws: 步骤 1 中的图像 1,1
    • Follow the procedures in Before You Begin.
    • Turn the computer over.
    • Loosen the captive screws from the memory module cover.
  2. Dell Inspiron 1420 Memory Module Replacement, Lifting the Cover: 步骤 2 中的图像 1,1
    • Lift the memory module cover and set it aside.
    • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
  3. Dell Inspiron 1420 Memory Module Replacement, Popping up the Memory Module: 步骤 3 中的图像 1,1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
  4. Dell Inspiron 1420 Memory Module Replacement, Removing the Module: 步骤 4 中的图像 1,1
    • Remove the module from the connector.
  5. Dell Inspiron 1420 Memory Module Replacement, Align the Notch: 步骤 5 中的图像 1,1
    • Align the notch in the module edge connector with the tab in the connector slot.
  6. Dell Inspiron 1420 Memory Module Replacement, Sliding the Module: 步骤 6 中的图像 1,1
    • Slide the module firmly into the slot at a 30-degree angle, and rotate the module down until it clicks into place. If you do not feel the click, remove the module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot. No error message indicates this failure.
  7. Dell Inspiron 1420 Memory Module Replacement, Replace the Module Cover: 步骤 7 中的图像 1,2 Dell Inspiron 1420 Memory Module Replacement, Replace the Module Cover: 步骤 7 中的图像 2,2
    • Replace the memory module cover and tighten the three captive screws.
终点
另外一个人完成了本指南。
Terrence15
于12/18/17注册
79,924 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
44 名成员
创作了1,996篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 366
