跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Do you find that your computer overheats frequently? Your heat sink may be faulty, which would cause your processor to run hotter than it should. Replacing your heat sink is very simple and can be done with the help of this guide.
配件
没有特定配件。
  1. Slide the two tabs to release the battery. Pull the battery out. Pull the battery out.
    • Slide the two tabs to release the battery.
    • Pull the battery out.
  2. Manta 螺丝刀工具包
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  3. Using a Phillips #00 screwdriver, remove the three 5mm screws. Lift the panel and set it aside. Lift the panel and set it aside.
    • Using a Phillips #00 screwdriver, remove the three 5mm screws.
    • Lift the panel and set it aside.
  4. Remove the four screws (3mm) securing the heat sink to the CPU. Lift the Heat sink out of the laptop. Lift the Heat sink out of the laptop.
    • Remove the four screws (3mm) securing the heat sink to the CPU.
    • Lift the Heat sink out of the laptop.
结论
David Nunez
于2014年09月23日注册
37 信誉积分
撰写一个指南
团队
USF Tampa, Team 2-4, Blackwell Fall 2014 USF Tampa, Team 2-4, Blackwell Fall 2014 的会员
USFT-BLACKWELL-F14S2G4
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 748
