跳转到主内容
Dell Inspiron 14-7437 Coin Cell Battery Replacement
你所需要的
  1. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: 步骤 1 中的图像 1,2 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: 步骤 1 中的图像 2,2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 步骤 2 中的图像 2,2
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: 步骤 3 中的图像 1,2 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 步骤 4 中的图像 1,1
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 步骤 5 中的图像 1,1
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Speaker: 步骤 6 中的图像 1,1
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 步骤 7 中的图像 1,3 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 步骤 7 中的图像 2,3 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 步骤 7 中的图像 3,3
    • Remove the speakers from the case.
  8. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Coin Cell Battery: 步骤 8 中的图像 1,1
    • Lift the coin cell battery wire, and carefully remove from motherboard.
    • There are little hooks that the wire is hooked under.
  9. Dell Inspiron 14-7437 Coin Cell Battery Replacement: 步骤 9 中的图像 1,2 Dell Inspiron 14-7437 Coin Cell Battery Replacement: 步骤 9 中的图像 2,2
    • Remove the Coin-Cell Battery from the case.
    • There is a small amount of adhesive on the bottom of the coin cell battery.
结论
另外一个人完成了本指南。
Katelyn Remy
于03/10/16注册
449 声望
创作了4篇指南
团队
UMass Dartmouth, Team 7-8, Catania Spring 2016 UMass Dartmouth, Team 7-8, Catania Spring 2016 的会员
UMASSD-CATANIA-S16S7G8
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 1,334
