跳转到主内容
Dell Inspiron 14-5447 Battery Replacement
你所需要的
  1. Dell Inspiron 14-5447 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Battery Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 14-5447 Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Battery Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 14-5447 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Battery Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 14-5447 Battery Replacement: 步骤 4 中的图像 2,2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 3,033
