跳转到主内容
Dell Inspiron 14-5415 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 14-5415 Hard Drive Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,2 Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Remove the screw from the hard drive using a Phillips #00 screwdriver.
  4. Dell Inspiron 14-5415 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Carefully pull the hard drive out of its position.
    • Be sure to handle the hard drive with care. It should not need to be pulled hard to remove.
结论
Ilana Ek-Adler
于02/09/23注册
85 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 11
总计 199
