跳转到主内容
Dell Inspiron 14-5415 Fan Replacement
你所需要的
  1. Dell Inspiron 14-5415 Fan Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 Fan Replacement, Fan: 步骤 3 中的图像 1,3 Dell Inspiron 14-5415 Fan Replacement, Fan: 步骤 3 中的图像 2,3 Dell Inspiron 14-5415 Fan Replacement, Fan: 步骤 3 中的图像 3,3
    • To access the Dell Inspiron fan flip the device upside down.
    • When identifying parts in the device, the Dell logo on the battery pack should be upright.
    • The fan is fastened at the top left hand corner of the device.
    • Remove two 4 mm screws using a Phillips #00 screwdriver.
  4. Dell Inspiron 14-5415 Fan Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 14-5415 Fan Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 14-5415 Fan Replacement: 步骤 4 中的图像 3,3
    • Gently pull on the fan adapter until it is disconnected from the port.
    • Don't pull too hard on the adapter as this may damage the part.
    • Carefully lift the fan out of the slot.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 7
总计 189
