跳转到主内容
Dell Inspiron 14-3452 Screen Replacement
你所需要的
  1. Dell Inspiron 14-3452 Screen Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 14-3452 Screen Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the battery by sliding the battery release latch to the left.
    • Pull the entire battery away from the backing.
  2. Dell Inspiron 14-3452 Screen Replacement, Random Access Memory (RAM): 步骤 2 中的图像 1,1
    • Ensure that the laptop is completely turned off and the battery is removed.
    • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
  3. Dell Inspiron 14-3452 Screen Replacement: 步骤 3 中的图像 1,1
    • Pull the backing away from the laptop.
  4. Dell Inspiron 14-3452 Screen Replacement: 步骤 4 中的图像 1,1
    • Locate the blue RAM chip sitting in the RAM bay.
    • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
  5. Dell Inspiron 14-3452 Screen Replacement: 步骤 5 中的图像 1,1
    • Pull the RAM chip away from the memory-module slot.
    • The RAM chip is now fully detached and ready to be replaced.
  6. Dell Inspiron 14-3452 Screen Replacement, Screen: 步骤 6 中的图像 1,1
    • Remove the ten Phillips Head 5 mm #0 screws from the computer backing.
    • Remove the one Phillips Head 3 mm #0 screw from the computer backing.
  7. Dell Inspiron 14-3452 Screen Replacement: 步骤 7 中的图像 1,2 Dell Inspiron 14-3452 Screen Replacement: 步骤 7 中的图像 2,2
    • Remove the white and black antenna cables from the wireless card.
  8. Dell Inspiron 14-3452 Screen Replacement: 步骤 8 中的图像 1,1
    • Remove the Phillips Head 3 mm #0 screw that is holding the wireless card in place.
  9. Dell Inspiron 14-3452 Screen Replacement: 步骤 9 中的图像 1,1
    • Slide the wireless card out of the wireless card bay.
  10. Dell Inspiron 14-3452 Screen Replacement: 步骤 10 中的图像 1,2 Dell Inspiron 14-3452 Screen Replacement: 步骤 10 中的图像 2,2
    • Using your fingertips remove the speaker cable from the motherboard by pulling the white connector away from the socket.
  11. Dell Inspiron 14-3452 Screen Replacement: 步骤 11 中的图像 1,1
    • Pry apart the keyboard assembly slowly as the keyboard cable will still be attached to the motherboard.
    • Use the blue Uspudger to pry apart the keyboard assembly from the bottom shell.
  12. Dell Inspiron 14-3452 Screen Replacement: 步骤 12 中的图像 1,1
    • Disconnect the keyboard cable from the motherboard by lifting the black latch and pulling the cable out of its socket.
  13. Dell Inspiron 14-3452 Screen Replacement: 步骤 13 中的图像 1,2 Dell Inspiron 14-3452 Screen Replacement: 步骤 13 中的图像 2,2
    • Disconnect the display cable from the motherboard by pulling the tape back and lifting the connector latch.
    • Pull the display cable away from the motherboard.
  14. Dell Inspiron 14-3452 Screen Replacement: 步骤 14 中的图像 1,1
    • Remove the power adapter cable from the motherboard by sliding the cable out of its socket.
  15. Dell Inspiron 14-3452 Screen Replacement: 步骤 15 中的图像 1,1
    • Turn laptop over to access the screen hinge screws.
    • Remove the two Phillips Head 5 mm #0 screws from the two hinges.
  16. Dell Inspiron 14-3452 Screen Replacement: 步骤 16 中的图像 1,2 Dell Inspiron 14-3452 Screen Replacement: 步骤 16 中的图像 2,2
    • Using your fingertips, gently pry up the inner edges of the display bezel.
    • Lift the display bezel off the display assembly.
  17. Dell Inspiron 14-3452 Screen Replacement: 步骤 17 中的图像 1,3 Dell Inspiron 14-3452 Screen Replacement: 步骤 17 中的图像 2,3 Dell Inspiron 14-3452 Screen Replacement: 步骤 17 中的图像 3,3
    • After removing the bezel, locate the tab indicated in the pictures.
    • Lift the tab as shown in the pictures.
    • Lift the gold latch securing the display cable to the socket.
    • Pull display cable away from the socket.
结论
Alec Siegel
于01/30/18注册
598 声望
创作了4篇指南
团队
Baylor, Team S2-G2, Johnson Spring 2018 Baylor, Team S2-G2, Johnson Spring 2018 的会员
BU-JOHNSON-S18S2G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 894
