跳转到主内容
Dell Inspiron 14 N4050 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 14 N4050 Hard Drive Replacement, Sliding the Hard-Drive Assembly: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Slide the hard-drive assembly to the left to disconnect it from the connector on the system board.
  2. Dell Inspiron 14 N4050 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 步骤 2 中的图像 1,1
    • Lift the hard-drive assembly out of the computer base.
  3. Dell Inspiron 14 N4050 Hard Drive Replacement, Remove the Screws: 步骤 3 中的图像 1,1
    • Remove the two screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 14 N4050 Hard Drive Replacement, Lifting the Hard-Drive Bracket: 步骤 4 中的图像 1,1
    • Lift the hard-drive bracket away from the hard drive.
  5. Dell Inspiron 14 N4050 Hard Drive Replacement, Placing the Hard-Drive Bracket: 步骤 5 中的图像 1,1
    • Place the hard-drive bracket on the NEW hard drive.
  6. Dell Inspiron 14 N4050 Hard Drive Replacement, Replace the Screws: 步骤 6 中的图像 1,1
    • Replace the two screws that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 14 N4050 Hard Drive Replacement, Placing the Hard-Drive Assembly: 步骤 7 中的图像 1,1
    • Place the hard-drive assembly on the computer base.
  8. Dell Inspiron 14 N4050 Hard Drive Replacement, Push the Hard Drive Assembly: 步骤 8 中的图像 1,1
    • Push the hard-drive assembly towards the right to connect it to the connector on the system board.
终点
Terrence15
于12/18/17注册
79,121 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,570
