跳转到主内容
Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement
你所需要的
  1. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Remove the Screw: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Solid-state drives are fragile. Exercise care when handling the solid-state drive.
    • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
    • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
  2. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Remove the Solid-State Drive: 步骤 2 中的图像 1,1
    • Slide and remove the solid-state drive from the solid-state drive slot.
  3. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Align the Notch: 步骤 3 中的图像 1,1
    • Align the notch on the solid-state drive with the tab on the solid-state drive slot, and slide the solid-state drive into the solid-state drive slot.
  4. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Align the Hole: 步骤 4 中的图像 1,1
    • Press the other end of the solid-state drive to align the screw hole on the solid-state drive with the screw hole on the computer base.
  5. Dell Inspiron 14 Gaming 7467 Solid-State Drive Replacement, Replace the Screw: 步骤 5 中的图像 1,1
    • Replace the screw (M2x3) that secures the solid-state drive to the computer base.
终点
Terrence15
于12/18/17注册
79,585 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 116
