跳转到主内容
Dell Inspiron 14 Gaming 7467 Display Assembly Replacement
你所需要的
  1. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Disconnecting the Camera Cable: 步骤 1 中的图像 1,1
  2. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Peel the Camera Cable: 步骤 2 中的图像 1,1
    • Peel off the camera cable from the computer base.
  3. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screw: 步骤 3 中的图像 1,1
    • Remove the screw (M2x3) that secures the display-cable bracket to the system board.
  4. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Removing the Cable Bracket: 步骤 4 中的图像 1,1
    • Lift the display-cable bracket off the system board.
  5. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Disconnecting the Display Cable: 步骤 5 中的图像 1,1
    • Using the pull-tab, disconnect the display cable from the system board.
  6. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Peeling the Display Cable: 步骤 6 中的图像 1,1
    • Peel off the display cable from the computer base.
  7. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screws: 步骤 7 中的图像 1,1
    • Remove the two screws (M2x3) that secure the display assembly to the computer base.
  8. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screws: 步骤 8 中的图像 1,1
    • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
  9. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Remove the Screws: 步骤 9 中的图像 1,1
    • Turn the computer over and open the display.
  10. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Lift the Display Assembly: 步骤 10 中的图像 1,1
    • Lift the display assembly off the computer base.
  11. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Align the Screw Hole: 步骤 11 中的图像 1,1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  12. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screws: 步骤 12 中的图像 1,1
    • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
  13. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screws: 步骤 13 中的图像 1,1
    • Close the display and turn the computer over.
  14. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screws: 步骤 14 中的图像 1,1
    • Replace the two screws (M2x3) that secure the display assembly to the computer base.
  15. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Adhere the Cable: 步骤 15 中的图像 1,1
    • Adhere the display cable and the camera cable to the computer base.
  16. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Route the Cables: 步骤 16 中的图像 1,1
    • Route the antenna cables through the routing guides on the computer base.
  17. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Connect the Cable: 步骤 17 中的图像 1,1
    • Connect the display cable and camera cable to the system board.
  18. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Align the Screw Hole: 步骤 18 中的图像 1,1
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  19. Dell Inspiron 14 Gaming 7467 Display Assembly Replacement, Replace the Screw: 步骤 19 中的图像 1,1
    • Replace the screw (M2x3) that secures the display cable bracket to the system board.
终点
Terrence15
于12/18/17注册
79,555 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 85
