跳转到主内容
Dell Inspiron 14 7447 Display Assembly Replacement
你所需要的
  1. Dell Inspiron 14 7447 Display Assembly Replacement, Disconnecting the Display Cable: 步骤 1 中的图像 1,2 Dell Inspiron 14 7447 Display Assembly Replacement, Disconnecting the Display Cable: 步骤 1 中的图像 2,2
  2. Dell Inspiron 14 7447 Display Assembly Replacement, Remove the Cable: 步骤 2 中的图像 1,1
    • Note the display cable routing and remove the cable from its routing guide.
  3. Dell Inspiron 14 7447 Display Assembly Replacement, Disconnecting the Antenna Cables: 步骤 3 中的图像 1,1
    • Disconnect the antenna cables from the wireless card.
  4. Dell Inspiron 14 7447 Display Assembly Replacement, Peeling the Tape: 步骤 4 中的图像 1,1
    • Peel off the tape that secures the antenna cables to the speaker.
  5. Dell Inspiron 14 7447 Display Assembly Replacement, Remove the Cables: 步骤 5 中的图像 1,1
    • Note the antenna cable routing and remove the cables from their routing guide.
  6. Dell Inspiron 14 7447 Display Assembly Replacement, Disconnecting the I/O Board Cable: 步骤 6 中的图像 1,1
    • Using the pull-tab, disconnect the I/O-board cable from the I/O board.
  7. Dell Inspiron 14 7447 Display Assembly Replacement, Remove the Cable: 步骤 7 中的图像 1,1
    • Note the I/O-board cable routing and remove the cable from its routing guide.
  8. Dell Inspiron 14 7447 Display Assembly Replacement, Remove the Screws: 步骤 8 中的图像 1,1
    • Remove the screws that secure the display assembly to the computer base.
  9. Dell Inspiron 14 7447 Display Assembly Replacement, Lifting the Display Assembly: 步骤 9 中的图像 1,1
    • Lift the display assembly off the computer base.
  10. Dell Inspiron 14 7447 Display Assembly Replacement, Placing the Display Assembly: 步骤 10 中的图像 1,1
    • Place the NEW display assembly on the computer base and align the screw holes on the display assembly with the screw holes on the computer base.
  11. Dell Inspiron 14 7447 Display Assembly Replacement, Replace the Screws: 步骤 11 中的图像 1,1
    • Replace the screws that secure the display assembly to the computer base.
  12. Dell Inspiron 14 7447 Display Assembly Replacement, Routing the I/O Board Cable: 步骤 12 中的图像 1,1
    • Route the I/O-board cable through the routing guides on the computer base.
  13. Dell Inspiron 14 7447 Display Assembly Replacement, Connecting the I/O Board Cable: 步骤 13 中的图像 1,1
    • Connect the I/O-board cable to the I/O board.
  14. Dell Inspiron 14 7447 Display Assembly Replacement, Routing the Antenna Cables: 步骤 14 中的图像 1,1
    • Route the antenna cables through the routing guides on the computer base.
  15. Dell Inspiron 14 7447 Display Assembly Replacement, Adhering the Tape: 步骤 15 中的图像 1,1
    • Adhere the tape securing the antenna cables to the speaker.
  16. Dell Inspiron 14 7447 Display Assembly Replacement, Connecting the Antenna Cables: 步骤 16 中的图像 1,1
    • Connect the antenna cables to the wireless card.
  17. Dell Inspiron 14 7447 Display Assembly Replacement, Routing the Display Cable: 步骤 17 中的图像 1,1
    • Route the display cable through the routing guides on the computer base.
  18. Dell Inspiron 14 7447 Display Assembly Replacement, Connecting the Display Cable: 步骤 18 中的图像 1,1
    • Connect the display cable to the system board and adhere the tape.
结论
另外一个人完成了本指南。
Terrence15
于12/18/17注册
79,555 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 1,050
