跳转到主内容
Dell Inspiron 14 5443 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 14 5443 Hard Drive Replacement, Removing screws: 步骤 1 中的图像 1,1
    • Remove the screws that secure the hard-drive assembly to the base frame.
  2. Dell Inspiron 14 5443 Hard Drive Replacement, Gently Lift Hard-Drive: 步骤 2 中的图像 1,1
    • Gently lift the hard-drive assembly out of the base frame and disconnect the hard-drive cable from the hard drive.
  3. Dell Inspiron 14 5443 Hard Drive Replacement, Removing Screws From Bracket: 步骤 3 中的图像 1,1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 14 5443 Hard Drive Replacement, Lifting Bracket: 步骤 4 中的图像 1,1
    • Lift the hard-drive bracket off the hard drive
  5. Dell Inspiron 14 5443 Hard Drive Replacement, Placing Bracket: 步骤 5 中的图像 1,1
    • Place the hard-drive bracket on the NEW hard drive.
  6. Dell Inspiron 14 5443 Hard Drive Replacement, Aligning the Screws: 步骤 6 中的图像 1,1
    • Align the screw holes on the hard drive-bracket with the screw holes on the hard drive.
  7. Dell Inspiron 14 5443 Hard Drive Replacement, Replace the Screws: 步骤 7 中的图像 1,1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 14 5443 Hard Drive Replacement, Connecting Hard-Drive To Cable: 步骤 8 中的图像 1,1
    • Connect the hard-drive cable to the hard drive.
  9. Dell Inspiron 14 5443 Hard Drive Replacement, Placing the Hard-Drive: 步骤 9 中的图像 1,1
    • Place the hard-drive assembly in the base frame and align the screw holes on the hard-drive assembly with the screw holes on the base frame.
  10. Dell Inspiron 14 5443 Hard Drive Replacement, Securing the Screws: 步骤 10 中的图像 1,1
    • Replace the screws that secure the hard-drive assembly to the base frame.
终点
另外一个人完成了本指南。
darrius
于03/26/18注册
5,213 声望
创作了30篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 230
