跳转到主内容
Dell Inspiron 14 5100 RAM Replacement
你所需要的
  1. Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: 步骤 1 中的图像 1,3 Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: 步骤 1 中的图像 2,3 Dell Inspiron 14 5100 RAM Replacement, Dell Inspiron 14 5100 Disassembly: 步骤 1 中的图像 3,3
    • Make sure to disconnect the power source to the device.
    • Remove nine screws securing the base cover of the laptop's keyboard assembly using the Phillips #0 screwdriver.
    • There are 2 sets of screws.
    • Remove the 3 captive screws.
    • Remove the 6M2*6 screws.
  2. Dell Inspiron 14 5100 RAM Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 14 5100 RAM Replacement: 步骤 2 中的图像 2,2
    • Pry open the laptop to separate the base cover from the keyboard assembly.
    • You may use your fingertips or use plastic opening tools.
  3. Dell Inspiron 14 5100 RAM Replacement, RAM: 步骤 3 中的图像 1,1
    • Fold back the thin plastic covers over the RAM slots.
  4. Dell Inspiron 14 5100 RAM Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 14 5100 RAM Replacement: 步骤 4 中的图像 2,2
    • Using the spudger, pull back the pins holding the RAM in place.
    • The RAM will slightly pop up from the motherboard.
  5. Dell Inspiron 14 5100 RAM Replacement: 步骤 5 中的图像 1,1
    • Remove the RAM card from the RAM slot using your fingers. Pull it gently in the direction of the laptop hinge.
    • Repeat Steps 3-5 for the other RAM slot.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 35
总计 1,843
