跳转到主内容
Dell Inspiron 14 3467 Base Cover Replacement
你所需要的
  1. Dell Inspiron 14 3467 Base Cover Replacement, Turning over the Computer: 步骤 1 中的图像 1,1
  2. Dell Inspiron 14 3467 Base Cover Replacement, Remove the Screws: 步骤 2 中的图像 1,1
    • Remove the eight screws that secure the base cover to the palm-rest assembly.
  3. Dell Inspiron 14 3467 Base Cover Replacement, Removing the Screws: 步骤 3 中的图像 1,1
    • Remove the two screws that secure the base cover to the palm-rest assembly.
  4. Dell Inspiron 14 3467 Base Cover Replacement, Removing the screws: 步骤 4 中的图像 1,1
    • Remove the three screws that secure the base cover to the palm-rest assembly.
  5. Dell Inspiron 14 3467 Base Cover Replacement, Turning the Computer over: 步骤 5 中的图像 1,1
    • Turn the computer over, and open the display.
  6. Dell Inspiron 14 3467 Base Cover Replacement, Removing the Screws: 步骤 6 中的图像 1,1
  7. Dell Inspiron 14 3467 Base Cover Replacement, Disconnecting the Optical-Drive Cable: 步骤 7 中的图像 1,1
    • Open the latch, and disconnect the optical-drive cable from the system board.
  8. Dell Inspiron 14 3467 Base Cover Replacement, Turning the Computer Over: 步骤 8 中的图像 1,1
    • Close the display, and turn the computer over
  9. Dell Inspiron 14 3467 Base Cover Replacement, Prying the Base Cover: 步骤 9 中的图像 1,1
    • Using a plastic scribe, pry the base cover off the palm-rest assembly.
  10. Dell Inspiron 14 3467 Base Cover Replacement, Lifting the Base Cover: 步骤 10 中的图像 1,1
    • Lift the base cover off the palm-rest assembly.
  11. Dell Inspiron 14 3467 Base Cover Replacement, Release the Optical-Drive Interposer: 步骤 11 中的图像 1,1
    • Release the optical-drive interposer from the tabs, and remove it from the base cover.
  12. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Optical-Drive: 步骤 12 中的图像 1,1
    • Slide the optical-drive interposer into the tabs on the NEW base cover and snap it into place.
  13. Dell Inspiron 14 3467 Base Cover Replacement, Placing the Base Cover: 步骤 13 中的图像 1,1
    • Place the base cover on the palm-rest assembly and route the optical-drive cable through the slot on the palm-rest assembly.
  14. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Tabs: 步骤 14 中的图像 1,1
    • Slide the tabs on the base cover into the slots on the palm-rest assembly, and snap the base cover into place.
  15. Dell Inspiron 14 3467 Base Cover Replacement, Sliding the Optical-Drive Cable: 步骤 15 中的图像 1,1
    • Slide the optical-drive cable into the connector on the system board and press down the latch to secure the cable.
  16. Dell Inspiron 14 3467 Base Cover Replacement, Placing the Screws: 步骤 16 中的图像 1,1
    • Replace the three screws (M2x5) that secure the base cover to the palm-rest assembly.
  17. Dell Inspiron 14 3467 Base Cover Replacement, Turning over the Computer: 步骤 17 中的图像 1,1
    • Close the display, and turn the computer over.
  18. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: 步骤 18 中的图像 1,1
    • Replace the three screws (M2x2) that secure the base cover to the palm-rest assembly.
  19. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: 步骤 19 中的图像 1,1
    • Replace the two screws (M2x5) that secure the base cover to the palm-rest assembly.
  20. Dell Inspiron 14 3467 Base Cover Replacement, Replacing the Screws: 步骤 20 中的图像 1,1
    • Replace the eight screws that secure the base cover to the palm-rest assembly.
终点
另外一个人完成了本指南。
darrius
于03/26/18注册
5,213 声望
创作了30篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 1,971
