跳转到主内容
Dell Inspiron 13z 5323 Memory Module Replacement
  1. Dell Inspiron 13z 5323 Memory Module Replacement, Popping up the Memory Module: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Close the display and turn the computer over.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Inspiron 13z 5323 Memory Module Replacement, Removing the Memory Module: 步骤 2 中的图像 1,2 Dell Inspiron 13z 5323 Memory Module Replacement, Removing the Memory Module: 步骤 2 中的图像 2,2
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 13z 5323 Memory Module Replacement, Align the Notch: 步骤 3 中的图像 1,2 Dell Inspiron 13z 5323 Memory Module Replacement, Align the Notch: 步骤 3 中的图像 2,2
    • CAUTION: If you need to install memory modules in two connectors, install a memory module in the connector labeled "DIMM A" before you install a memory module in the connector labeled "DIMM B."
    • Align the notch on the memory module with the tab on the memory-module connector.
  4. Dell Inspiron 13z 5323 Memory Module Replacement, Installing the Memory Module: 步骤 4 中的图像 1,1
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not in stalled properly, the computer may not boot.
结论
Terrence15
于12/18/17注册
79,858 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,994篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 206
