跳转到主内容
Dell Inspiron 13z 5323 Keyboard Replacement
你所需要的
  1. Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,3 Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,3 Dell Inspiron 13z 5323 Keyboard Replacement, Keyboard: 步骤 1 中的图像 3,3
    • First flip the device over, so the bottom is facing you. Then you will remove the highlighted screw.
  2. Dell Inspiron 13z 5323 Keyboard Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 13z 5323 Keyboard Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 13z 5323 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Flip over the laptop and open it so that the screen is facing you.
    • At the top side of the Keyboard closest to the screen you will find 2 inset plastic clips. The clips are shown here in red. Using the flat and of the metal prying tool bend the clips in and at the same time lift the keyboard up.
    • Their is a ribbon connector still attached to the bottom of the keyboard. You should be careful not to damage this cable.
  3. Dell Inspiron 13z 5323 Keyboard Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 13z 5323 Keyboard Replacement: 步骤 3 中的图像 2,2
    • The ribbon connector seen in yellow can be removed by flipping up the plastic hinge clamp with a thin plastic pry lever
结论
Chase Hussey
于03/08/17注册
201 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 370
