跳转到主内容
Dell Inspiron 13z 5323 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 13z 5323 Hard Drive Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 13z 5323 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: 步骤 2 中的图像 1,2 Dell Inspiron 13z 5323 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: 步骤 2 中的图像 2,2
    • Disconnect the hard-drive cable connector from the hard-drive assembly.
  3. Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Assembly: 步骤 3 中的图像 1,1
    • Lift the hard-drive assembly away from the computer base.
  4. Dell Inspiron 13z 5323 Hard Drive Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Bracket: 步骤 5 中的图像 1,2 Dell Inspiron 13z 5323 Hard Drive Replacement, Lifting the Hard-Drive Bracket: 步骤 5 中的图像 2,2
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 13z 5323 Hard Drive Replacement, Align the Screw Holes: 步骤 6 中的图像 1,1
    • Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 13z 5323 Hard Drive Replacement, Replace the Screws: 步骤 7 中的图像 1,1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 13z 5323 Hard Drive Replacement, Connecting the Hard-Drive Cable: 步骤 8 中的图像 1,2 Dell Inspiron 13z 5323 Hard Drive Replacement, Connecting the Hard-Drive Cable: 步骤 8 中的图像 2,2
    • Connect the hard-drive cable connector to the hard-drive assembly.
  9. Dell Inspiron 13z 5323 Hard Drive Replacement, Align the Screw Holes: 步骤 9 中的图像 1,1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  10. Dell Inspiron 13z 5323 Hard Drive Replacement, Replace the Screws: 步骤 10 中的图像 1,1
    • Replace the screws that secure the hard-drive assembly to the computer base.
结论
Terrence15
于12/18/17注册
79,091 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
42 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 590
