跳转到主内容
Dell Inspiron 13z 5323 Fan Assembly Replacement
你所需要的
  1. Dell Inspiron 13z 5323 Fan Assembly Replacement, Fan Assembly: 步骤 1 中的图像 1,3 Dell Inspiron 13z 5323 Fan Assembly Replacement, Fan Assembly: 步骤 1 中的图像 2,3 Dell Inspiron 13z 5323 Fan Assembly Replacement, Fan Assembly: 步骤 1 中的图像 3,3
    • First flip the device over, so the bottom is facing you. Then you will remove the 9 red highlighted screws.
    • The orange highlighted screw is held in place with a washer, so when it is loosened and the plate is removed, the screw will stay in the plate.
    • Once the orange screw is loosened you can then remove the small plate on the bottom of the device.
  2. Dell Inspiron 13z 5323 Fan Assembly Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 13z 5323 Fan Assembly Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 13z 5323 Fan Assembly Replacement: 步骤 2 中的图像 3,3
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a small flathead screwdriver to push the tabs so the keyboard will pop out.
    • You will have to flip a small tab up where this thin wire goes into the insert, so the wire can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Fan Assembly Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13z 5323 Fan Assembly Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13z 5323 Fan Assembly Replacement: 步骤 3 中的图像 3,3
    • Remove the highlighted 4 screws and then use the plastic separator to remove the palm rest.
    • The cooling fan is now visible on the left side of the laptop.
  4. Dell Inspiron 13z 5323 Fan Assembly Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 13z 5323 Fan Assembly Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 13z 5323 Fan Assembly Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the screw holding the fan in place.
    • Once the screw is removed, use tweezers to pull on the tab as shown. Lift up on the tab to create separation between the fan and the rest of the laptop.
    • The purple tabbed ribbon connector will have to be released, as it prohibits the fan from being separated from the system. You can do so, by lifting the small tab identical to the ribbon connector used to keep the keyboard in place.
    • Detach the wires connecting the fan as shown to the laptop. Once they are free, the fan can be taken out.
结论
David Gilleran
于03/08/17注册
201 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 325
