跳转到主内容
Dell Inspiron 13z 5323 Battery Replacement
你所需要的
  1. Dell Inspiron 13z 5323 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Dell Inspiron 13z 5323 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Dell Inspiron 13z 5323 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Remove nine screws from the bottom case.
    • The highlighted captive screw on the base cover is held in place with a washer, so when it is loosened and the cover is removed, the screw will stay in the plate.
    • Once the captive screw is loosened, remove the small base cover on the bottom of the device.
  2. Dell Inspiron 13z 5323 Battery Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 13z 5323 Battery Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 13z 5323 Battery Replacement: 步骤 2 中的图像 3,3
    • There are 3 slots on the top of the keyboard where you will have to use a thin tool, such as a flathead screwdriver to push the tabs so the keyboard will pop out.
    • Be careful when pushing in the keyboard tabs, as they may break if they if too much pressure is applied to them.
    • You will have to flip a small tab up where the ribbon connector goes into the insert, so the connector can be released and the keyboard can be removed.
  3. Dell Inspiron 13z 5323 Battery Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13z 5323 Battery Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13z 5323 Battery Replacement: 步骤 3 中的图像 3,3
    • Remove the highlighted 4 screws and then use the plastic separator to remove the palm rest.
    • Be careful when separating the palm rest from the laptop, because being too aggressive with it can cause the small clips that hold the palm rest in place to break .
  4. Dell Inspiron 13z 5323 Battery Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 13z 5323 Battery Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 13z 5323 Battery Replacement: 步骤 4 中的图像 3,3
    • Remove the screws surrounding the battery and unplug the cable in the top left corner to then remove the battery.
结论
Chase Hussey
于03/08/17注册
201 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 839
