跳转到主内容
Dell Inspiron 1300 Hard Drive Replacement
你所需要的
  1. Dell Inspiron 1300 Hard Drive Replacement, Loosen the Captive Screws: 步骤 1 中的图像 1,1
  2. Dell Inspiron 1300 Hard Drive Replacement, Lifting the Cover: 步骤 2 中的图像 1,1
    • Lift the cover off the computer and set it aside.
  3. Dell Inspiron 1300 Hard Drive Replacement, Sliding the Hard Drive: 步骤 3 中的图像 1,1
    • Slide the hard drive carrier away from the screw holes, and then use the tab to lift the hard drive straight up to remove it from the computer.
  4. Dell Inspiron 1300 Hard Drive Replacement, Installing the NEW Hard Drive: 步骤 4 中的图像 1,1
    • NOTICE: Use firm and even pressure to slide the drive into place. If you use excessive force, you may damage the connector.
    • Seat the NEW hard drive into the bay, and then slide it into the connector by sliding it toward the screw holes until it is fully seated.
  5. Dell Inspiron 1300 Hard Drive Replacement, Replace the Cover: 步骤 5 中的图像 1,1
    • Replace the cover and tighten the screws.
结论
Terrence15
于12/18/17注册
78,592 声望
创作了441篇指南
团队
Informative Technologies Inc. Informative Technologies Inc. 的会员
Community
38 名成员
创作了1,982篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 18
总计 1,079
