跳转到主内容
Dell Inspiron 13-7373 Motherboard Replacement
你所需要的
  1. Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Dell Inspiron 13-7373 Motherboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Motherboard Replacement, Battery: 步骤 2 中的图像 1,1
    • Use a Phillips screwdriver to remove the four screws holding the battery in place.
  3. Dell Inspiron 13-7373 Motherboard Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 13-7373 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pull the plastic tab on the battery cable to disconnect the cable from the battery.
  4. Dell Inspiron 13-7373 Motherboard Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 13-7373 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the battery from the laptop.
  5. Dell Inspiron 13-7373 Motherboard Replacement, Fan: 步骤 5 中的图像 1,1
    • Remove the two screws holding the cover for the fan.
  6. Dell Inspiron 13-7373 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
  7. Dell Inspiron 13-7373 Motherboard Replacement, Network Card: 步骤 7 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  8. Dell Inspiron 13-7373 Motherboard Replacement, Daughterboard: 步骤 8 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  9. Dell Inspiron 13-7373 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the daughterboard.
  10. Dell Inspiron 13-7373 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Remove the seven 2mm screws securing the motherboard.
  11. Dell Inspiron 13-7373 Motherboard Replacement: 步骤 11 中的图像 1,3 Dell Inspiron 13-7373 Motherboard Replacement: 步骤 11 中的图像 2,3 Dell Inspiron 13-7373 Motherboard Replacement: 步骤 11 中的图像 3,3
    • Release the IO Board Cable.
    • Release the Touchpad cable.
    • Release the keyboard back-light cable.
    • Release the keyboard cable.
    • Release the eDP cable.
    • Release the dc-in cable.
    • Release the cable for the LED charging indicator by gently pulling up on the connector.
  12. Dell Inspiron 13-7373 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Gently lift up on the motherboard to remove it.
结论
另外一个人完成了本指南。
John Egan
于10/25/19注册
485 声望
创作了3篇指南
团队
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 19
过去 30 天: 24
总计 1,419
