跳转到主内容
加入维修社区 - 创建账户
Dell Inspiron 13-7373 Fan Replacement
你所需要的
  1. Dell Inspiron 13-7373 Fan Replacement, Back Cover: 步骤 1 中的图像 1,3 Dell Inspiron 13-7373 Fan Replacement, Back Cover: 步骤 1 中的图像 2,3 Dell Inspiron 13-7373 Fan Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
    添加评论
  2. Dell Inspiron 13-7373 Fan Replacement, Fan: 步骤 2 中的图像 1,1
    • Remove the two screws holding the cover for the fan.
    询问修复机器人
    添加评论
  3. Dell Inspiron 13-7373 Fan Replacement: 步骤 3 中的图像 1,1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
    询问修复机器人
    添加评论
结论
To reassemble your device with the new fan, follow these instructions in reverse order.
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 的会员
UMASSD-O'CONNELL-F19S1G4
3 名成员
创作了5篇指南
2指南评论
This was most helpful. We have a Dell 7373 model and the fan is quite noisy. We are going to disassemble and clean/replace it. Your tutorial explained it all. Thank you.
martyfukui - 回复 分享
these 7373 seem to have a fan issue- I do IT for a business that has like 10 of them and at least 2 developed the same issue after a couple years- ordered new fans off of Amazon (tons of them and all look same except some have a flange on the bottom?) and no way to differentiate quality- both redeveloped the problem soon after installing fan- both were clean inside w no obvious issue- guessing the thin case has possibly bent down a tad and puts pressure on it- might take apart and see if I can bend part of case out a bit?) geez dell.
Garry Masters - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 31
总计 1,638
