跳转到主内容
Dell Inspiron 13-7373 Daughterboard Replacement
你所需要的
  1. Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: 步骤 1 中的图像 1,3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: 步骤 1 中的图像 2,3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Daughterboard Replacement, Network Card: 步骤 2 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  3. Dell Inspiron 13-7373 Daughterboard Replacement, Daughterboard: 步骤 3 中的图像 1,1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  4. Dell Inspiron 13-7373 Daughterboard Replacement: 步骤 4 中的图像 1,1
    • Remove the daughterboard.
结论
Kristen Gismondi
于11/12/14注册
92,015 声望
创作了241篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,450篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 15
总计 345
