跳转到主内容
Dell Inspiron 13-7370 Fan Replacement
你所需要的
  1. Dell Inspiron 13-7370 Fan Replacement, Fan: 步骤 1 中的图像 1,3 Dell Inspiron 13-7370 Fan Replacement, Fan: 步骤 1 中的图像 2,3 Dell Inspiron 13-7370 Fan Replacement, Fan: 步骤 1 中的图像 3,3
    • Make sure the laptop is turned off and not connected to a charging cable.
    • Using a Phillips #0 screwdriver, remove the ten (10) 2.5 mm screws fastening the bottom cover.
  2. Dell Inspiron 13-7370 Fan Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13-7370 Fan Replacement: 步骤 2 中的图像 2,2
    • Starting around the edges of the laptop, lift and remove the back cover. Apply pressure upwards, until you hear a popping noise.
    • Moving clockwise around the laptop, continue to apply pressure upwards, using your fingers or a plastic pick, until the bottom cover pops out of its locks.
  3. Dell Inspiron 13-7370 Fan Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 13-7370 Fan Replacement: 步骤 3 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws.
    • Carefully disconnect the battery from the motherboard.
  4. Dell Inspiron 13-7370 Fan Replacement: 步骤 4 中的图像 1,2 Dell Inspiron 13-7370 Fan Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the fan in place.
  5. Dell Inspiron 13-7370 Fan Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 13-7370 Fan Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 13-7370 Fan Replacement: 步骤 5 中的图像 3,3
    • Lifting the fan, disconnect it from the laptop by grasping the connector (circled in red), and pulling out horizontally.
    • Do NOT pull the connecter upwards, as this may damage the socket you are pulling it out of.
  6. Dell Inspiron 13-7370 Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the fan from the device.
结论
另外一个人完成了本指南。
Zayed Azam
于05/16/21注册
133 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 913
