跳转到主内容
Dell Inspiron 13-7359 WLAN Adaptor Replacement
你所需要的
  1. Dell Inspiron 13-7359 WLAN Adaptor Replacement, Battery: 步骤 1 中的图像 1,1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 WLAN Adaptor Replacement: 步骤 2 中的图像 1,1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 WLAN Adaptor Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: 步骤 3 中的图像 3,3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 WLAN Adaptor Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 13-7359 WLAN Adaptor Replacement: 步骤 4 中的图像 3,3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 WLAN Adaptor Replacement, WLAN Adaptor: 步骤 5 中的图像 1,1
    • Unhook both of the wires attached to the WLAN adaptor.
  6. Dell Inspiron 13-7359 WLAN Adaptor Replacement: 步骤 6 中的图像 1,1
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  7. Dell Inspiron 13-7359 WLAN Adaptor Replacement: 步骤 7 中的图像 1,1
    • Gently remove the WLAN adaptor.
结论
Bo Yi Lim
于04/02/19注册
205 声望
创作了2篇指南
团队
IUPUI, Team S3-G4, Harley Spring 2019 IUPUI, Team S3-G4, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S3G4
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 165
