跳转到主内容
Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement
你所需要的
  1. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, Battery: 步骤 1 中的图像 1,1
    • First flip over the laptop to expose the back panel
    • Use a Phillips #0 screwdriver to unscrew all ten 7mm Phillips head screws holding the back panel in place.
  2. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 2 中的图像 1,1
    • With a plastic spudger, carefully remove the back panel by prying each corner off individually
    • Slowly pick up the panel and set it aside
  3. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 3 中的图像 3,3
    • The battery will be the largest black component in the device located near the bottom edge. Using a Phillips #0 screwdriver, unscrew the two 3mm Phillips head screws holding in the battery.
  4. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 4 中的图像 3,3
    • To remove the old battery, slightly lift the bottom edge of the battery with your hands
    • Now slowly pull the battery towards you to fully detach the battery
  5. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
  6. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 6 中的图像 1,2 Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 6 中的图像 2,2
    • Lift and hold the hard drive in your left hand.
    • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
    • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
  7. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, WLAN Adaptor: 步骤 7 中的图像 1,1
    • Unhook both of the wires attached to the WLAN adaptor.
  8. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 8 中的图像 1,1
    • Remove the 3.9mm Phillips screw using Phillips #0 screwdriver.
    • Once the screw is removed, one end of the WLAN adaptor will raise up.
  9. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 9 中的图像 1,1
    • Gently remove the WLAN adaptor.
  10. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement, USB/SD Card Reader IO Circuit Board: 步骤 10 中的图像 1,1
    • Using the plastic opening tool, unhook the black cable as shown.
  11. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 11 中的图像 1,1
    • Gently pull to unplug the speaker cable.
  12. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 12 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the 3.9mm Phillips screw as shown.
  13. Dell Inspiron 13-7359 USB/SD Card Reader IO Circuit Board Replacement: 步骤 13 中的图像 1,1
    • Gently raise the USB/SD Card Reader IO Circuit Board and pull the part free from the device.
结论
Bo Yi Lim
于04/02/19注册
205 声望
创作了2篇指南
团队
IUPUI, Team S3-G4, Harley Spring 2019 IUPUI, Team S3-G4, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S3G4
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 361
